I installed "CodeWarrior Development Studio for StarCore 3900FP DSP v10.9.0 - Windows.exe". I received also service pack "CodeWarrior Development Studio for StarCore 3900FP DSP v10.9.0 SP1" . How I install it?
2,497 次查看
yaakovbar-on
1,972 次查看
Daniel_Popa
Hi Yaakov Bar-on,
Just open the CodeWarrior IDE, and within the top menus select: Help/Install New Software ... option
Then you simply have to follow the onscreen directions by selecting Add.../Local -> path to your local Service Pack container.
Hope this helps!
1,972 次查看
lunminliang
This service pack should be installed on top of CodeWarrior Development Studio for StarCore 3900FP DSP v10.9.0.
CodeWarrior installation instructions are provided in the Service_Pack_Updater_Quickstart.pdf document included in CW 10.9.0 layout. Please check the section A Select the Service Pack Archive at page 2 for information on how to install the patch.
The com.freescale.sc.10.9.0.sp.win.updatesite_1.1.1.zip archive should not be manually installed.
1,973 次查看
Daniel_Popa
Hi Yaakov Bar-on,
Hope this helps!
