upgrading from 6.3 to 6.4 floating point issues
1,742 次查看
JackAbbott
While working on a project with the Coldfire 5213, I blew out the code boundary on
the software that came with the evaluation kit. I used a CD from one of the licensed
versions my company owns (version 6.4) and got a temp license from Freescale, while
waiting to buy another copy. When I went to compile my project I got a message that
I had undefined _fpscr fellow engineer told me he had the same message and added
fenv.cf.c and it solved his problem. When I added it, it caused 1000 errors.  I tried a
dozen things and added files nothing seemed to help. Found a couple of references
on the forums but no concrete answers.
The fundamental issue is; I don't know what I'm doing when it comes to the fp libraries
and such. Any help to point me in the right direction would be appreciated.
Cheers
       Jack
标签 (1)
标记 (1)
1 回复
769 次查看
CrasyCat
Specialist III
Hello
  CodeWarrior for Coldfire V6.4 is linking Reduced Working Set Libraries to MCF5213 projects.
  Please refer to {Install}\Help\PDF\ColdFire_Build_Tools_Reference.pdf, chapter "Coldfire Runtime Libraries" ->
  "MSL for Coldfire Development" -> "Reduces Working Set Libraries" for more information on that.
  Following thread explains you how to add floating point support to your project.
CrasyCat
