register usage
register usage
1,054 次查看
erez_huji
First, I'm sorry for my English grammar..
I'v been trying to reduce the overhead caused by entering into an ISR.
One of the solutions is to save only a fraction of the CPU's registers.
In order to do that, while playing safe with the interrupted thread, I will have to make that the ISR will run using that fraction of the CPU's registers only.
Is there a way to order the compiler to use only some specific registers while compiling?
Important: I'm using Freescals's MPC5553...
Erez
标记 (1)
615 次查看
J2MEJediMaster
Specialist I
I would check in the Build Tools reference manual (it should be in the Help directory) and look up the _declspec(interrupt) pragma. I do not know if it would will provide the precise control that you need, but it would be the place to start.
---Tom
