I posted an exported project to this community but the explanation wasn't attached. See Const_print_prob.zip but it is only an exported CodeWarrior file of program described in attached text document which describes the problem in detail.
Original Attachment has been moved to: Constant_print_prob.txt.zip
Solved! Go to Solution.
Indeed, the bug is reproducible with the mentioned steps. I logged a bug to compiler team and let you know when this will be fixed.
Thank you,
Marius
Thank you,
Marius
