In my current project, I'm using a non-volatile battery backed SRAM, and now, I would like to declare variables that will be placed in that memory but that will not be initialized to zero at init.
In my lcf I added a memory section like that:
MEMORY{... saved_ram: org = 0x20000000, len = 0x00020000...}SECTIONS{GROUP : { .dataSavedRam : {} } >} and in my code:
#pragma push#pragma section data_type ".dataSavedRam" ".dataSavedRam"#pragma pop__declspec(section ".dataSavedRam") int savedVarExample;
But during startup my variable is initialized to 0 in the function __init_data (in __start.c).
So, what is the best solution to avoid that?
thank you.
