dynamic allocate memory in my application?
1,880件の閲覧回数
jixiang
My application C programs run on either RAM or Flash Programmer using M52223 controller and CodeWarrior 6.3. In my C code, I just try to use standard C lib: calloc(..) and malloc(..) to dynamically allocate memory for diffrent variables.  I get an error message: "Bus Error ..."
I would appreciate it if someone can help or give the direction to solve the problem.
Dong Sun
タグ(1)
1,023件の閲覧回数
CrasyCat
Specialist III
Hello
  1- Did you include stdlib.h in the source file where you try to use calloc?
  2- Where did you define your heap? How big is it defined? You should be able to see that in
      the .map file generated by the linker
CrasyCat
