MCF51QM128 vs. MCF51QE128
TremalNaik
Hi everybody,
I'm beggining with this devices and I'm trying to understand a little about this.  Freescale says that CodeWarrior is a good IDE  for developing.
In my situatuion, I've installed the 6.3 version and qhen I try create a new project, the underivate windows do not offers the MCF51QM128 which is the one I'm using.
The most similar name that appears is MCF51QE128.
Will be there some problem if I work from this last?
Thank you so much!
BlackNight
Hi, not sure if I understand your question. But CW for MCU6.3 is old, and there is the MCU10.x version (eclipse based) already out for more than 2 years. All new devices are supported in 10.x ongoing.
BK
BlackNight
Use the eclipse based CodeWarrior for MCU10 (www.freescale.com/cwmcu10).
It comes with MCF51QM128 support.
BK
TremalNaik
Thanks BlackNight. So do not exists some CodeWarrior version?
BlackNight
BK
TremalNaik
Ok. My MCF51QM128 I believe has less than 2 years. I'll follow your idea.
thank you so much
