Looking for some utility to convert my project  file(.mcp)  to batch file.
3,327件の閲覧回数
Anamika
Is there a utility in CodeWarrior to convert my project  file (.mcp)  to batch file. (.bat) . I need this batch file for reverse engineering process.
I am using 'CodeWarrior for Coldfire architectures. Profession Edition.'.
THanks for your time.
タグ(1)
3 返答(返信)
1,273件の閲覧回数
jhopewell
Metrowerks projects are pretty much a black art. You can dump out a 96k line xml file and parse that... good luck.
I have had to convert projects in the distant past, I had to do it the old fashoned way, re-add all the files directories dependencies to the dsp... or makefile.
1,273件の閲覧回数
Anamika
Hi,  Thanks for your reply. The reason I am looking for this utility is, we are trying to convert our COdeWarrior project which is already coded into design model. i,e going backwards .
FOr the software I am using to do this reverse engineering, I need to specify the .bat file or the .dsp file,  so that the software generates the design model of our project.
Other solution is to specify individual files (classes), but there are many  includes and defines in each file, which has to be taken care.
Cheers,
1,273件の閲覧回数
UK_CF_FAE
I'm not aware of any such utility, but to be fair to you, I'm not certain exactly what you are trying to do. I get worried when I see the words Reverse Engineer.
