Jtag Connection to QorIQ p1021: [CCS last error: ELF is not in expected HALT mode ](CCSProtocolPlugin)
alfonsokame
I'm having trouble to connect to my Bareboard based on the P1021 processor using CodeWarrior for PA Version: 10.1.2. I checked the JTAG pins and they seem to be OK. While executing the initialization script (p1021RDB_init_core.tcl), the debugger seems not be able to stop and halt the processor. It hangs while executing this script.
Any idea what is wrong here? The goal is to flash the bootloader to the SPI Flash.
Here is the Log
ccs_open
    ipaddr = 127.0.0.1
    port = 41475
    timeout = 15
    serverh = 0
    ccs_open; ccs_error = 0
ccs_get_connection_count
    serverh = 0
    count = 1
    ccs_get_connection_count; ccs_error = 0
ccs_available_connections
    serverh = 0
    count = 0
    ccs_available_connections; ccs_error = 0
    serverh = 0
    count = 0
ccs_config_cc
    serverh = 0
    config_string = utap:0
    ccs_config_cc; ccs_error = 0
ccs_read_register
    coreh = [serverh:0;cc_index:0;chain_pos:1]
    index = 2032
    count = 2
    size = 4
    value: (size = 8)
         FFFFFFF8 00000000
    ccs_read_register; ccs_error = 0; duration=1 ms
ccs_read_register
    index = 8
    count = 2
    size = 4
    value: (size = 8)
         00000000 00000000
ccs_read_register
    index = 1
    count = 1
    size = 4
    value: (size = 4)
         00000000
ccs_read_mem
    addr = [space:0;size:4;address:0xffffff00]
    data: (size = 256)
         09000000 00000000 01000000 03000000
         00000000 03000000 00000000 00000000
         D4120000 00000000 00000000 00000000
         00000000 00000000 00000000 00000000
    ccs_read_mem; ccs_error = -2147418106; duration=2 ms
    Error message: cannot start SAP transaction
Executing Initialization File: C:\Users\InstAdmin\workspace1\fuziuzu-core0/CFG/P1021RDB_init_core.tcl
ccs_stop_core
radix x
cmdwin::eclipse::config hexprefix 0x
cmdwin::eclipse::config MemIdentifier v
cmdwin::eclipse::config MemWidth 32
cmdwin::eclipse::config MemAccess 32
cmdwin::eclipse::config MemSwap off
cmdwin::reg e500 Special Purpose Registers/PIR %d -np
    ccs_stop_core; ccs_error = 0
ccs_read_register
    index = 2032
    count = 1
    size = 4
    value: (size = 4)
         FFFFFFFC
ccs_read_reg
    index = 63
    count = 1
    value: (size = 1)
         0x00000000
    ccs_read_reg; ccs_error = 0; duration=1 ms
ccs_read_reg
    index = 406
    count = 1
    value: (size = 1)
         0x00000000
    ccs_read_reg; ccs_error = 0; duration=0 ms
ccs_read_reg
    index = 415
    count = 1
    value: (size = 1)
         0x00000000
ccs_read_register
    index = 286
    count = 1
    size = 4
    value: (size = 4)
         00000000
ccs_read_mem
    data: (size = 256)
         DF120000 00000000 00000000 00000000
ccs_read_register
    index = 285212672
    count = 1
    size = 4
cmdwin::stop
    value: (size = 4)
         66029B02
    ccs_read_register; ccs_error = -2147418106; duration=3 ms
ccs_read_register
    index = 2032
    count = 2
    size = 4
    value: (size = 8)
         FFFFFFF8 00000000
ccs_read_register
    index = 1
    count = 1
    size = 4
    value: (size = 4)
         00000000
    ccs_read_register; ccs_error = 0; duration=0 ms
thread break: Stopped, 0x0, 0x0, cpuPowerPCBig,  Connected (state, tid, pid, cpu, target)
cmdwin::reg e500 Special Purpose Registers/IVPR = 0xFFFF0000
ccs_write_register
    index = 63
    count = 1
    size = 4
    value: (size = 4)
         FFFF0000
    ccs_write_register; ccs_error = 0; duration=1 ms
ccs_read_register
    index = 63
    count = 1
    size = 4
    value: (size = 4)
         FFFF0000
cmdwin::reg e500 Special Purpose Registers/IVOR15 = 0x0000F000
ccs_write_register
    index = 415
    count = 1
    size = 4
    value: (size = 4)
         0000F000
ccs_read_register
    index = 415
    count = 1
    size = 4
    value: (size = 4)
         0000F000
cmdwin::reg e500 Special Purpose Registers/IVOR6 = 0x0000F700
ccs_write_register
    index = 406
    count = 1
    size = 4
    value: (size = 4)
         0000F700
ccs_read_register
    index = 406
    count = 1
    size = 4
    value: (size = 4)
         0000F700
cmdwin::reg e500 Special Purpose Registers/IAC1 = 0xfffffffc
ccs_write_register
    index = 312
    count = 1
    size = 4
    value: (size = 4)
         FFFFFFFC
ccs_read_register
    index = 312
    count = 1
    size = 4
    value: (size = 4)
         FFFFFFFC
cmdwin::reg e500 Special Purpose Registers/DBCR0 = 0x40800000
ccs_write_register
    index = 308
    count = 1
    size = 4
    value: (size = 4)
         40800000
ccs_read_register
    index = 308
    count = 1
    size = 4
    value: (size = 4)
         40800000
cmdwin::reg e500 Special Purpose Registers/DBCR1 = 0x00000000
ccs_write_register
    index = 309
    count = 1
    size = 4
    value: (size = 4)
         00000000
ccs_read_register
    index = 309
    count = 1
    size = 4
    value: (size = 4)
         00000000
cmdwin::reg Standard Special Purpose Registers/MSR = 0x02000200
ccs_write_register
    index = 2034
    count = 1
    size = 4
    value: (size = 4)
         02000200
ccs_read_register
    index = 2034
    count = 1
    size = 4
    value: (size = 4)
         02000200
cmdwin::eclipse::config runcontrolsync off
cmdwin::go
ccs_read_reg
    index = 308
    count = 1
    value: (size = 1)
         0x40800000
ccs_read_reg
    index = 2034
    count = 1
    value: (size = 1)
         0x02000200
ccs_write_reg
    index = 308
    count = 1
    value: (size = 1)
         0x41800000
    ccs_write_reg; ccs_error = 0; duration=0 ms
ccs_out
    ccs_io addr: (size = 4)
         0x00000000 0x00007531 0x00000000 0x00000000
    value: (size = 8)
         00000000 00000200
    ccs_out; ccs_error = 0; duration=0 ms
ccs_run_core
    ccs_run_core; ccs_error = 0
cmdwin::wait 50
cmdwin::eclipse::config runcontrolsync on
cmdwin::stop
ccs_stop_core
    ccs_stop_core; ccs_error = -2147418101
    Error message: ELF is not in expected HALT mode
Any idea??
Thanks a lot!
hwrobel
The typical reset vector is 0xffff_fffc. So if you see an access to 0xffff_ff00, I would assume that the debugger tries to read in a page of your boot flash to be able to show you the instructions correctly.
Any NOR flash would not lead to bad behavior as a boot chip select will always complete the transaction due to the GPCM being used.
Do not only check the cfg_ signals, BTW. The EC doc describes several signals with footnotes which are not standard cfg_, but are still quite relevant for proper operation.
If you can’t figure it out at all, then you could turn CCS logging and start a tech support request on the freescale web with the debugger log, your init scripts and maybe even schematic excerpts.
Heinz
hwrobel
Your description seems to indicate that this is about your board design and not our RDB.
Go through the EC document and check every pin with a footnote thoroughly with a scope during reset. I mean it.
Most common cause for such things are missing pullups/pulldowns on pins listed in the EC with a footnote, or external logic overdriving pullups/downs during reset, thereby messing up the reset state of the chip.
If you have a BSDL scan tool, then this might help to verify pin states during reset. Note that via BSDL you will only see externally driven pin state. Internal resistors on otherwise open pins may not be visible.
Also, don't use an RDB script "as is" on a custom board. Very likely that won't work as expected. If in doubt, start with a script with minimalistic content just to see if you can "Connect" and stop at a reset vector.
Hope this helps,
Heinz
alfonsokame
Hello Heinz,
thanks for your reply!
Im still struggling in order to get the p1021 based bareboard run!
All I checked all the reset configuration signals (cfg_..). They all seem to match their Reset state that is described in the reference manual. While trying to connect to the BareBoard, I notice that one step before the init_core.tcl is being executed, A memory or IO is trying to be read and there is an error:
ccs_read_mem
    data: (size = 256)
    ccs_read_mem; ccs_error = -2147418106; duration=2 ms   :smileyminus:
    Error message: cannot start SAP transaction    :smileyminus:
Which Moduleis he trying to read on the address ffffff00? Is it Memory? How to configure it?
Many Thanks for your reply!!
hwrobel
Heinz
alfonsokame
Thanks very much Heinz,
We found the problem here, It was due to 2 too weak pull-up resistances on the spi-clock and the MOSI. It had an influence on the JTAG connection
Thanks very much for your support once again
esode
Hello Alfonsokame,
We are using P2010 chip with CW and CW-TAP on a custom board, which has 2 more chips on the JTAG. We have a very similar problem to yours, like "Error message: cannot start SAP transaction". However, we are not using any SPI protocol on the board. I wonder whether you are using SPI  then  it brings  out the problem you mentioned.  I want to get a clue whether SPI hardware connections on the board are related to the problem.
I appreciate your comments.
Eser
