We are using MPC8323E-RDB board i want to know which JTAG tool use to communicate and pragramm the flash on MPC8323E-RDB board. We have Codewarrior USB TAB (Freescale ) tool. But we are not sure which software to use to programm the Flash that supports MPC8323E-RDB board. Any suggestions will be appriaciated.
If you're using the CodeWarrior USB TAP, then try CodeWarrior's built-in Flash programmer. Or, you can try one of the Flash Programmer applications from P&E Microsystems at www.pemicro.com.
