How to create a static library with Codewarrior for MPC55xx in COMMAND LINE
frenchdavid
Hi all,
I am running CodeWarrior for MPC55xx v2.2 in command line with Cygwin and i want to create a static library (.a) from all object files but I don't find the executable file to use. What is strange is that, by using the IDE I can create it !!!
Can anyone help me ?
CrasyCat
Specialist III
Hello
In fact to create a static library you use the linker (mwldeppc.exe) and specify the option -library in the command line.
CrasyCat
frenchdavid
Hi CrasyCat,
It works, thanks a lot!!
french david
