Help to use Code generated by RAppID-MPC5554 in CW MPC55xx V2.2
2,027 次查看
n_
I use Rapid Application Initialization and Documentation Toll (RAppID) for MPC5554 to generate Code. But when I create new MPC5554's project and add these codes, There are many Errors. I have tried using RAppID to generate code for 3 different compilers (Metrowerks, Diab, GreenHills), but there are still many errors and the errors are different.
Please guide me to use Code that generated by RAppID-MPC554 in CodeWarrior.
标记 (1)
982 次查看
Voxan
Hi there,
I would guess Rapid is not generating standard C code, that may explain different errors using different compilers.
Back to your issue, I'm afraid you will have to investigate errors one by one and adjust settings/configurations accordingly.
Hope this helps...
