I want to define a particular long value to be stored in a particular RAM address. I have a value called flash_process. I need the bootloader code and program code to access this value at the same RAM address. The bootloader code will access the first 4096 of flash. The program flash code will start at flash address 4096 .I want to define a function to be stored at a particular flash address. Such as main() function (main.c).Is this a more defined help file to better explain for manipulating the link (.LCF) file and to better explain the different pragma definitions.. ?I am using CodeWarrior 6.3 with the MCF52223 microcontroller (256k flash, 32k ram)..Thank you,
Message Edited by J2MEJediMaster on 2007-04-12 10:26 AM
