Connect USB tap on simili P1010RDB
Search instead for
charlesretaille
We developed a board similar to the P1010RDB and we cannot get the USB tap to connect properly to this board.
The probe connects to a real P1010RDB without problem, therefore the SW configuration of the connection, and the probe HW are fine.
The connection process to our board stops at
     "Executing Initialization File: [...]P1010RDB_init_core.tcl"
There's no error of any kind poping up, so my question is what can be the cause of this behaviour ?
Is there somewhere a log or error list, that could help to understand what's the issue ?
NOTE: I know, the issue must be on our HW, and of course I'm not asking for you to correct our schematic but merely a way for us to do so.
Tags (2)
marius_grigoras
From ccs log it seems to be a problem when the CW is trying to stop your core. Can you tell me please what did you change to your board?
Thank you,
Marius
marius_grigoras
Being a custom board mostly the initialization file will fail.
Please enable the CCS log from Debugger Settings -> Edit -> from Advanced CCS Settings tab select Enable logging and let me know the log output.
Secondly, you can make a try with the SRAM tcl file (this doesn't use the DDR). You can find this file here: PA\PA_Support\Initialization_Files\QorIQ_P1\P1010RDB_init_sram_flash.tcl
Marius
charlesretaille
Please find below the logs from the console
About the "SRAM tcl file", I tried and I get the same logs...
ccs_open
    ipaddr = 127.0.0.1
    port = 41475
    timeout = 15
    serverh = 0
    ccs_open; ccs_error = 0
ccs_get_connection_count
    serverh = 0
    count = 1
    ccs_get_connection_count; ccs_error = 0
ccs_available_connections
    serverh = 0
    count = 0
    ccs_available_connections; ccs_error = 0
    serverh = 0
    count = 0
ccs_config_cc
    serverh = 0
    config_string = utap:0
    ccs_config_cc; ccs_error = 0
    serverh = 0
    count = 1
    serverh = 0
    count = 1
ccs_cc_version
    serverh = 0
    cc = 0
    version.major = 1
    version.minor = 3
    ccs_cc_version; ccs_error = 0
ccs_set_timeout
    serverh = 0
    timeout = 15
    ccs_set_timeout; ccs_error = 0
ccs_config_server
    serverh = 0
    cc = 0
    server_config = 0
    value = 10230
    ccs_config_server; ccs_error = 0
ccs_get_config_chain
    serverh = 0
    device_list: (size = 0)
    ccs_get_config_chain; ccs_error = 0
ccs_config_chain
    serverh = 0
    cc = 0
    device_list: (size = 1)
        device[0]:: core_type=p1010(219)
    ccs_config_chain; ccs_error = 0
    serverh = 0
    serverh = 0
ccs_send_message
    coreh = [serverh:0;cc_index:0;chain_pos:0]
    message = 3
    ccs_send_message; ccs_error = 0
ccs_get_server_config
    serverh = 0
    cc = 0
    server_config = 3
    value = 0
    ccs_get_server_config; ccs_error = 0
ccs_config_server
    serverh = 0
    cc = 0
    server_config = 3
    value = 1
ccs_reset_to_mixed
    chain_pos: (size = 1)    { 0 (halt) }
    ccs_reset_to_mixed; ccs_error = 0; duration=1904 ms
ccs_config_server
    serverh = 0
    cc = 0
    server_config = 3
    value = 0
ccs_read_register
    index = 2032
    count = 1
    size = 4
    value: (size = 4)
         FFFFFFFC
    ccs_read_register; ccs_error = 0; duration=1 ms
ccs_read_register
    index = 2032
    count = 1
    size = 4
    value: (size = 4)
         FFFFFFFC
ccs_in
    ccs_io addr: (size = 4)
         0x00000000 0x00002710 0x00000000 0x00000000
    value: (size = 8)
         482B0E58 61B00925
    ccs_in; ccs_error = 0; duration=1 ms
ccs_in
         0x00000000 0x00002711 0x00000000 0x00000000
    value: (size = 8)
         CCDA0C80 50414A80
    ccs_in; ccs_error = 0; duration=2 ms
ccs_in
         0x00000000 0x00002712 0x00000000 0x00000000
    value: (size = 8)
         68ED2010 038262A6
ccs_in
         0x00000000 0x00002713 0x00000000 0x00000000
    value: (size = 8)
         4B2A10F2 52CB3938
ccs_in
         0x00000000 0x00002714 0x00000000 0x00000000
    value: (size = 8)
         689C5002 A4A45E46
ccs_in
         0x00000000 0x00002715 0x00000000 0x00000000
    value: (size = 8)
         70084413 98416B18
ccs_in
         0x00000000 0x00002716 0x00000000 0x00000000
    value: (size = 8)
         68D81380 28511414
ccs_in
         0x00000000 0x00002717 0x00000000 0x00000000
    value: (size = 8)
         331A049A 0394008A
ccs_in
         0x00000000 0x00002718 0x00000000 0x00000000
    value: (size = 8)
         53D0D062 5200C880
ccs_in
         0x00000000 0x00002719 0x00000000 0x00000000
    value: (size = 8)
         08983812 02041508
ccs_in
         0x00000000 0x0000271a 0x00000000 0x00000000
    value: (size = 8)
         8C8610D0 13E0424F
ccs_in
         0x00000000 0x0000271b 0x00000000 0x00000000
    value: (size = 8)
         90517482 39015208
ccs_in
         0x00000000 0x0000271c 0x00000000 0x00000000
    value: (size = 8)
         60025620 8240242D
ccs_in
         0x00000000 0x0000271d 0x00000000 0x00000000
    value: (size = 8)
         83A00240 1160C840
ccs_in
         0x00000000 0x0000271e 0x00000000 0x00000000
    value: (size = 8)
         48349182 8E881030
ccs_in
         0x00000000 0x0000271f 0x00000000 0x00000000
    value: (size = 8)
         041590C6 3494E882
ccs_in
         0x00000000 0x00002720 0x00000000 0x00000000
    value: (size = 8)
         C8121022 20810901
ccs_in
         0x00000000 0x00002721 0x00000000 0x00000000
    value: (size = 8)
         6BC0084A 83099110
ccs_in
         0x00000000 0x00002722 0x00000000 0x00000000
    value: (size = 8)
         B608A06A 388C8220
ccs_in
         0x00000000 0x00002723 0x00000000 0x00000000
    value: (size = 8)
         100001D6 C680E891
ccs_in
         0x00000000 0x00002724 0x00000000 0x00000000
    value: (size = 8)
         F2003E23 11F28400
ccs_in
         0x00000000 0x00002725 0x00000000 0x00000000
    value: (size = 8)
         600102E2 1820882E
ccs_in
         0x00000000 0x00002726 0x00000000 0x00000000
    value: (size = 8)
         518810D8 13014394
ccs_in
         0x00000000 0x00002727 0x00000000 0x00000000
    value: (size = 8)
         82B40016 71389300
ccs_in
         0x00000000 0x00002728 0x00000000 0x00000000
    value: (size = 8)
         82E80210 88420020
ccs_in
         0x00000000 0x00002729 0x00000000 0x00000000
    value: (size = 8)
         410D00A8 808001D1
ccs_in
         0x00000000 0x0000272a 0x00000000 0x00000000
    value: (size = 8)
         B87D9021 08B29008
ccs_in
         0x00000000 0x0000272b 0x00000000 0x00000000
    value: (size = 8)
         5ACC04C4 6820C131
ccs_in
         0x00000000 0x0000272c 0x00000000 0x00000000
    value: (size = 8)
         404A2006 C020880C
ccs_in
         0x00000000 0x0000272d 0x00000000 0x00000000
    value: (size = 8)
         70C47428 00A0E234
ccs_in
         0x00000000 0x0000272e 0x00000000 0x00000000
    value: (size = 8)
         7E4C1A60 A075C808
ccs_in
         0x00000000 0x0000272f 0x00000000 0x00000000
    value: (size = 8)
         A92C534A 90474306
ccs_read_register
    index = 2032
    count = 2
    size = 4
    value: (size = 8)
         FFFFFFFC 00000000
ccs_read_register
    index = 8
    count = 2
    size = 4
    value: (size = 8)
         00000000 00000000
ccs_read_register
    index = 1
    count = 1
    size = 4
    value: (size = 4)
         00000000
ccs_read_mem
    addr = [space:0;size:4;address:0xffffff00]
    data: (size = 256)
         FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
    ccs_read_mem; ccs_error = 0; duration=10 ms
Executing Initialization File:C:\Users\axess\workspace\test-core0/CFG/P1010RDB_init_core.tcl
ccs_stop_core
radix x
cmdwin::eclipse::config hexprefix 0x
cmdwin::eclipse::config MemIdentifier v
cmdwin::eclipse::config MemWidth 32
cmdwin::eclipse::config MemAccess 32
cmdwin::eclipse::config MemSwap off
cmdwin::reg GUT/PORBMSR %x -np
    ccs_stop_core; ccs_error = 0
ccs_read_register
    index = 2032
    count = 1
    size = 4
    value: (size = 4)
         FFFFFFFC
ccs_read_reg
    index = 63
    count = 1
    value: (size = 1)
         0x00000000
    ccs_read_reg; ccs_error = 0; duration=1 ms
ccs_read_reg
    index = 406
    count = 1
    value: (size = 1)
         0x00000000
ccs_read_reg
    index = 415
    count = 1
    value: (size = 1)
         0x00000000
ccs_read_mem
    data: (size = 256)
    ccs_read_mem; ccs_error = 0; duration=3 ms
ccs_read_register
    index = 285212672
    count = 1
    size = 4
    value: (size = 4)
         00000003
    ccs_read_register; ccs_error = 0; duration=0 ms
ccs_read_register
    index = 285212672
    count = 1
    size = 4
    value: (size = 4)
         00000003
ccs_read_register
    index = 285212673
    count = 1
    size = 4
    value: (size = 4)
         00000001
    ccs_read_register; ccs_error = 0; duration=16 ms
ccs_read_register
    index = 285212693
    count = 1
    size = 4
    value: (size = 4)
         00000002
    ccs_read_register; ccs_error = 0; duration=2 ms
ccs_read_register
    index = 285212713
    count = 1
    size = 4
    value: (size = 4)
         00000003
ccs_read_reg
    index = 30000
    count = 1
    value: (size = 1)
         0x00000ff7
ccs_read_reg
    index = 30000
    count = 1
    value: (size = 1)
         0x00000ff7
    ccs_read_reg; ccs_error = 0; duration=0 ms
ccs_read_mem
    addr = [space:0;size:4;address:0xff7e0004]
    data: (size = 4)
         8A370000
    ccs_read_mem; ccs_error = 0; duration=1 ms
ccs_in
    value: (size = 8)
         482B0E58 61B00925
ccs_in
    value: (size = 8)
         CCDA0C80 50414A80
ccs_in
    value: (size = 8)
         68ED2010 038262A6
ccs_in
    value: (size = 8)
         4B2A10F2 52CB3938
ccs_in
    value: (size = 8)
         689C5002 A4A45E46
ccs_in
    value: (size = 8)
         70084413 98416B18
ccs_in
    value: (size = 8)
         68D81380 28511414
ccs_in
    value: (size = 8)
         331A049A 0394008A
ccs_in
    value: (size = 8)
         53D0D062 5200C880
ccs_in
    value: (size = 8)
         08983812 02041508
ccs_in
    value: (size = 8)
         8C8610D0 13E0424F
ccs_in
    value: (size = 8)
         90517482 39015208
ccs_in
    value: (size = 8)
         60025620 8240242D
ccs_in
    value: (size = 8)
         83A00240 1160C840
ccs_in
    value: (size = 8)
         48349182 8E881030
ccs_in
    value: (size = 8)
         041590C6 3494E882
ccs_in
    value: (size = 8)
         C8121022 20810901
ccs_in
    value: (size = 8)
         6BC0084A 83099110
ccs_in
    value: (size = 8)
         B608A06A 388C8220
ccs_in
    value: (size = 8)
         100001D6 C680E891
ccs_in
    value: (size = 8)
         F2003E23 11F28400
ccs_in
    value: (size = 8)
         600102E2 1820882E
ccs_in
    value: (size = 8)
         518810D8 13014394
ccs_in
    value: (size = 8)
         82B40016 71389300
ccs_in
    value: (size = 8)
         82E80210 88420020
ccs_in
    value: (size = 8)
         410D00A8 808001D1
ccs_in
    value: (size = 8)
         B87D9021 08B29008
ccs_in
    value: (size = 8)
         5ACC04C4 6820C131
ccs_in
    value: (size = 8)
         404A2006 C020880C
ccs_in
    value: (size = 8)
         70C47428 00A0E234
ccs_in
    value: (size = 8)
         7E4C1A60 A075C808
ccs_in
    value: (size = 8)
         A92C534A 90474306
ccs_read_register
    index = 2032
    count = 2
    size = 4
    value: (size = 8)
         FFFFFFFC 00000000
ccs_read_register
    index = 8
    count = 2
    size = 4
    value: (size = 8)
         00000000 00000000
ccs_read_register
    index = 1
    count = 1
    size = 4
    value: (size = 4)
         00000000
thread break: Stopped, 0x0, 0x0, cpuPowerPCBig,  Connected (state, tid, pid, cpu, target)
cmdwin::reg e500 Special Purpose Registers/IVPR = 0xFFFF0000
ccs_write_register
    index = 63
    count = 1
    size = 4
    value: (size = 4)
         FFFF0000
    ccs_write_register; ccs_error = 0; duration=0 ms
ccs_read_register
    index = 63
    count = 1
    size = 4
    value: (size = 4)
         FFFF0000
cmdwin::reg e500 Special Purpose Registers/IVOR15 = 0x0000F000
ccs_write_register
    index = 415
    count = 1
    size = 4
    value: (size = 4)
         0000F000
ccs_read_register
    index = 415
    count = 1
    size = 4
    value: (size = 4)
         0000F000
cmdwin::reg e500 Special Purpose Registers/IVOR6 = 0x0000F700
ccs_write_register
    index = 406
    count = 1
    size = 4
    value: (size = 4)
         0000F700
    ccs_write_register; ccs_error = 0; duration=1 ms
ccs_read_register
    index = 406
    count = 1
    size = 4
    value: (size = 4)
         0000F700
cmdwin::reg e500 Special Purpose Registers/IAC1 = 0xfffffffc
ccs_write_register
    index = 312
    count = 1
    size = 4
    value: (size = 4)
         FFFFFFFC
ccs_read_register
    index = 312
    count = 1
    size = 4
    value: (size = 4)
         FFFFFFFC
cmdwin::reg e500 Special Purpose Registers/DBCR0 = 0x40800000
ccs_write_register
    index = 308
    count = 1
    size = 4
    value: (size = 4)
         40800000
ccs_read_register
    index = 308
    count = 1
    size = 4
    value: (size = 4)
         40800000
cmdwin::reg e500 Special Purpose Registers/DBCR1 = 0x00000000
ccs_write_register
    index = 309
    count = 1
    size = 4
    value: (size = 4)
         00000000
ccs_read_register
    index = 309
    count = 1
    size = 4
    value: (size = 4)
         00000000
cmdwin::reg Standard Special Purpose Registers/MSR = 0x02000200
ccs_write_register
    index = 2034
    count = 1
    size = 4
    value: (size = 4)
         02000200
ccs_read_register
    index = 2034
    count = 1
    size = 4
    value: (size = 4)
         02000200
cmdwin::reg IFC/CSOR0 = 0x0000E00C
ccs_write_mem
    addr = [space:0;size:4;address:0xff71e130]
    data: (size = 4)
         0000E00C
    ccs_write_mem; ccs_error = 0; duration=0 ms
cmdwin::go 1
ccs_read_reg
    index = 308
    count = 1
    value: (size = 1)
         0x40800000
ccs_read_reg
    index = 2034
    count = 1
    value: (size = 1)
         0x02000200
ccs_write_reg
    index = 308
    count = 1
    value: (size = 1)
         0x41800000
    ccs_write_reg; ccs_error = 0; duration=1 ms
ccs_out
         0x00000000 0x00007531 0x00000000 0x00000000
    value: (size = 8)
         00000000 01FD7E20
    ccs_out; ccs_error = 0; duration=1 ms
ccs_run_core
    ccs_run_core; ccs_error = 0
cmdwin::stop
ccs_stop_core
    ccs_stop_core; ccs_error = -2147483635
    Error message: ELF is not in expected HALT mode
marius_grigoras
Thank you,
Marius
