ColdFire CAU Software Library
1,328 次查看
kecart
Is the ColdFire CAU Software Library mentioned in MCFCAUUG (Date 02/2007) available?  I don't need the full SSL/SSH functions right now, only the AES encrypt/decrypt algorithms.
标记 (1)
874 次查看
rkawano
I am looking for the same library (source code, if possible). If only the object code is available (cau_libs.o, I already got it), can anybody say if it should work for any Coldfire with CAU (MCF52259, for instance)?
kecart, were you able to get any response for your question?
