Codwarrior crashes when attempting connect to 5208EVB via USB
2,862 次查看
wermgerl
I have a eval 5208 eval board and a usb multilink from P&E but can't seem to get them to connect
When I select "connect" from the debug menu, I get a message that says "Select port number within valid range"  And then codewarrior crashes with an  unhandled exception.
I've set the target up to use the factory defaults for PEMICRO_USB.
I've downloaded installed the latest drivers from P&E
Any hints on what to try next?
标记 (1)
1,206 次查看
marc_paquette
What version of CodeWarrior for ColdFire do you use?
Marc.
