CW10, MQX 3.6 MQX_PATH
WHookway
How does MQX_PATH get set, trying to compile a sample MQX program and MQX_PATH is not set to the default installation directory.  If set at all it is c:\ and my MQX files are at c:\Program Files\Freescale\Freescale MQX 3.6, I do not see how to correct this.
Will
WHookway
All,
Highlight project, right click and select properties.  Select C/C++ Build then Build Variables, the MQX_PATH will be there.  It may need to be fixed depending upon where your project is located.
Will
