CW 6.1 file limitation?
Search instead for
Senior Contributor I
Hello!
I'm developping an application using CW6.1 and MCF51QE128.... is there any file limitation on the Special Edition?
It tells me something like  "shell returned error 2 file xxxxxxxxxxxxxxx (wichfile=100)"
Now, I don't know why is not telleing it anymore. But I've that doubt. Is there any file limitation? Maybe 100 files?
I look at the license.dat file. The 'title' says
# ( 843): HC08 V6.0 Special Edition
Is that correct? because the version I'm using is 6.1 and im working with CFv1 not HC08.
Thanks!!!
Specialist III
Hello
The license for CodeWarrior MCU V6.x should not include any limitation in number of files.
Can you please attach the license.dat file of your special edition? I want to check whether it is correct.
CrasyCat
