I'm using a P1021 on an X-ES Xpedite5551 board. I'm also using CodeWarrior for Power Architecture Version: 10.5.1 with the CodeWarrior USB TAP JTAG.
I'm attempting to download and elf file to memory and debug.
When I click debug, I get the following error:
Failed to resume target process.
CCSProtocolPlugin : Error writing memory
[CCS last error: ELF is not in expected HALT mode ]
However, I am able to attach the debugger.
I've attached the CW log files
Solved! Go to Solution.
I've been able to resolve this issue by adding the initialization script in the debug connection settings.
Debug Configurations -> My Debug connection /> Under target Settings click Edit -> Under target Click Edit ->
Thanks :smileyhappy:
