'other' section in map file
GregYurko
I made some changes that should have reduced my overall code size by 8K or so.  It turns out that it didn't.  When I look at the map file, i see that the 'other' section has increased by 11K.  Where should I look to figure out why the 'other' section has grown so much?
CrasyCat
Specialist III
Hello
The other element contains all objects which are not defined in a specific module (object file),
There are many different things like the stack, the startup data structure, copy down information, vectors defined in prm's, included srecords and more.
Look in the list which is sorted by address to find out where all the memory goes, not primarily in the module list.
CrasyCat
CrasyCat
Specialist III
Hello
CrasyCat
