I am running Code Warrior V5 for 9S12 with a P&E USB BDM Multilink.
I have no problem erasing and programming PFLASH (program flash), but I have not been able to erase or program DFLASH (data flash).
Here is what I did and the responses I got:
in>flash init autoid
FP: FLASH parameters loaded for MC9S12XEQ384_V3(NVMIF2 rev 1,1,1,1,1) from C:\Freescale\CodeWarrior_for_S12X_V5_0\prog\FPP\mcu02DB.fpp
MCU clock speed: 4017000 Hz
Block Module Name Address Range Status
0 PFLASH 4000 - 7FFF Blank - Unselected
1 PFLASH C000 - FFFF Blank - Unselected
2 PFLASH E08000 -E7BFFF Blank - Unselected
3 PFLASH F08000 -FFBFFF Blank - Unselected
4 DFLASH 800 -1F0BFF Programmed - Unselected
in>flash erase 4
Vppon command file is disabled.
Vppoff command file is disabled.
in>flash
in>
I also tried using "flash select 4" before erasing, but the result was no different.
