flash write and read/
670件の閲覧回数
guochunhua
Dear sir/ms.
I have made a program in codewarrior 10.7,the cpu is mc56f84789. In PE, I have met two problems, they are follows.
1. I have added a flash module in my program,but I can not read or write the flash correctly, can you give me an example that how I read or write the flash? It is wonderful if you can give me a video.
2. I have added eFlexPWM module, there is a fault in my program when the PWM fault pin is high level. If there is a fault, sometimes enter the fault interrupt,sometimes does not enter the fault interrupt, how can I set the fault pin to enter the fault interrupt ? or which options can I set to enter the fault interrupt? can you give me an example? It is wonderful if you can give me a video.
Best regards.
chunhua guo
461件の閲覧回数
ZhangJennie
Hi Chunhua,
This is a duplicate question of
https://community.nxp.com/thread/469202
We have support engineer already contacted you via that link.
Please have a look, if that's not clear, please contact the support engineer with reply.
Jennie Zhang
