I do not understand the problem
I declare in header file
typedef union{ byte bRS_Event; struct { byte bStatus_1:1; byte bStatus_2:1; }u;}ST_FLAGS_RS_EVENT;extern ST_FLAGS_RS_EVENT stRS_Event;
L1823: External object stRS_Event in C:\Prog\GRx\Project1.2\Project_Data\Standard\ObjectCode\trames_rs.c.o created by default
Help me
Thank you
已解决! 转到解答。
Hello
The code snippet you have provided below is showing the declaration for variable stRS_Event.
Did you place a definition fro the same variable in one of your application .c file?
Definition should look as follows and must reside in a source file (not an include file).:
CrasyCat
Hello
CrasyCat
