Dear CrasyCat,
For example HC08QL series has a lin harwdare or you can use a software uart at HC908QY series but you can not simulate factors as:
What if you have little modified input bit rate?
What if you have wrong lenght of break?
What if you take in rx different bits that tx?
These and others tests you can not make with this debugger.
Finally you can not test the lin driver at slave side if it is conforms with protocol.
You must buy very expensive tools to test lin at hardware level so if there is a stimulator control that you can trigger input at specified intervals thats would very nice.
Do you know if the stimulator component will support at newer edition?
Or do you know some else Debugger for make these tests?
Kostas
