code warrior 10.1 compile error:" make: *****[psp KINETIS/kinetis.obj]error"
2,746 次查看
aarontc
i have installed 10.1 and latest compile patch with mqx 3.7
when i compile psp , bsp and hello example the same error message shows.
Some one can help me fix it?Thx
2,367 次查看
CarlFST60L
Senior Contributor II
There is likely an error in your user_config.h file. I had the same #define in the header twice i.e.
#define this
#define this
The error and console outputs are often quite misleading in diagnosing errors...
6 回复数
2,367 次查看
tavo
hi , how you solve the problem error, you copy and paste #DEFINE what?
2,368 次查看
CarlFST60L
#define this
#define this
2,367 次查看
aarontc
tried to change the directory to c:\freescale instead of c:\program files(x86)\freescal
but still gettiing these errors
2,367 次查看
aarontc
solved
2,367 次查看
CarlFST60L
Would you mind sharing your fix? I am assuming it is a path issue...?
2,367 次查看
CarlFST60L
If anyone else has this problem, I had managed to copy and paste the same #define twice in the user_config.h, this comes up as the above error which is not very descriptive.
