What was changed from CW 6.0 to 6.1?
已解决
跳至解决方案
3,615 次查看
UcTechnoGeek
When is Freescale going to add OSBDM support for the ColdFire V1 devices?
uCTechnoGeek
标签 (1)
标记 (1)
1 解答
1,266 次查看
CrasyCat
Specialist III
Hello
Changes between V6.0 and V6.1 are documented in file "Welcome_CW_MCUs.txt", which is located in your V6.1 installation directory.
I will try to find out what are the plans around support for OSBDM.
CraysCat
在原帖中查看解决方案
3 回复数
1,267 次查看
CrasyCat
Specialist III
Hello
CraysCat
1,266 次查看
UcTechnoGeek
Thanks. :smileyhappy:
I was just trying to avoid downloading the "mega file", just to find out what changed.
Would Freescale consider adding a "here's what changed" to the website, so we can see if we want to upgrade before downloading the program?
It has gotten much better, but in the past you could spend days "fixing" your project, just because you upgraded the IDE.
uCTechnoGeek
1,266 次查看
CrasyCat
Specialist III
Hello
Will suggest that to our marketing people.
In the mean time, find attached the text file describing changes between V6.0 & V6.1
CrasyCat
