Unusual 'expected error' for HC08!
1,476 次查看
coolgoose
I'm trying to build an application around HCS08 MCU and MC13213 transceiver using CW IDE version 5.7.
The following code is from the application source code file:
extern tTxPacket gsTxPacket;
extern tRxPacket gsRxPacket;
/* Initialize the packet.*/
gsTxPacket.u8DataLength = 0; -----------------------> Error occurs here
gsTxPacket.pu8Data = &gau8TxDataBuffer[0];
gsTxPacket.u8MaxDataLength = 128;
gsRxPacket.u8DataLength = 0;
I'm getting an error as follows:
[Error : c2450: Expected: ;]---->for the indicated line
thanks in advance
Message Edited by J2MEJediMaster on 2007-04-12 10:58 AM
标记 (1)
773 次查看
CrasyCat
Specialist III
Hello
would need the whole definition of type tTxPacket to investigate.
CrasyCat
