Storing variable in flash
3,472 次查看
rmaier
I'm using an MC9S12P128 MCU, and I'd like to store some constants in D-flash. I have the D-flash segment defined as
DFLASH        = READ_ONLY   0x010400 TO 0x0113FF;
So, when I go to write the constant, I use the following:
#pragma CONST_SEG CAL_VAL
volatile const unsigned char __near constant1=0x7F;
When I look at where this is in the memory, it shows up as 0xC015. To me, that's nowhere in the range define above. What am I missing here?
3,321 次查看
ZhangJennie
Hi Robert.
I just made a quick test but I didn't reproduce your problem.
see attached demo code and video.
Jennie Zhang
5 回复数
3,322 次查看
ZhangJennie
Hi Robert.
Jennie Zhang
3,321 次查看
rmaier
I do not see any attachments. Can you please post?
3,321 次查看
ZhangJennie
Can't you see it?
here is the screenshot of it
3,321 次查看
rmaier
Thank you, Jennie. The video was very helpful. I missed some items in the prm file.
Not sure how I missed the video. My appologies.
3,321 次查看
rmaier
I hacked a solution. I defined constant1 in D-flash as follows:
const unsigned char constant1 @ 0x0400;
Then I can write to D-flash at this location, and all is well...
