Software debug written by corewarrior runs, and the power goes out
794 次查看
15258085388
Software written by CW can be run with debug, as well as with debug turned off.But when the battery is switched on the program doesn't respond and that's why.Do you need any configuration
标记 (1)
1 回复
733 次查看
FelipeGarcia
I am sorry for the late reply. This question was in a non-tracked community space.
Are you still facing this issue? If so, could you please give more details about it. Also, which MCU are you working on?
Felipe
