S9S12G64实时中断
Search instead for
S9S12G64实时中断
求S9S12G64 实时中断的配置的寄存器中文说明;
Hello ,
unfortunately, we don't have a Chinese document for 9s12g64 interrupt configuration.
Instead, I found a set of 9S12G demo code which include interrupt usage. see:
http://cache.nxp.com/assets/documents/data/en/application-notes/AN4455.pdf
http://cache.nxp.com/assets/documents/data/en/application-notes-software/AN4455SW.zip
The attached technical note is about how to implement the interrupt routine.
I think it is simple and readable. Hope it can help you.
Jennie Zhang
