Using CodeWarrior for MCU, v10.7, on Qorivva target, I am not able to understand the size of the current structures: S1 has size 1 (not expected - I was expecting 4, following the section "21.4.6 Bitfields" of the documentation MCU_Power-Architecture_Compiler.pdf), wheras S2 has size 4 (as expected):
struct S1 {
unsigned int a: 4;
unsigned int b: 3;
unsigned char c:1;
struct S2 {
unsigned char c:1;
unsigned int a: 4;
unsigned int b: 3;
Could you elaborate?
Thanks for your support,
Pascal.
PS: I have attached the project to highlight it.
Original Attachment has been moved to: MPC-C.7z.zip
