Problems of the code generated by lin stack configuration tool(NCFTool)
1,632 次查看
jeffcharles
I am using the NCF tool to generate three configuration files. I found something wrong with the interface function in lin_cfg.h:
The signal size of 'S2M_Sig3' is 3 and the offset is 6, so bit 6 and bit 7 of byte 1 and bit 0 of byte 2 in the signal array 'lin_pFrameBuf' is occupied by it.pic2.JPG
But the following macro only access the byte 1 about 'S2M_Sig3', why?
Please give me support. Thank you!
Jeff
1,615 次查看
dianabatrlova
Hi Jeff,
Could you, please, specify which MCU you use?
Thank you.
Diana
1,601 次查看
jeffcharles
Hi Diana,
I am using the MC9S12ZVL32
Jeff
