Out of allocation space in segment RAM at address 0x3E65? MCS9XDP512.
已解决
跳至解决方案
6,397 次查看
Pang
Hi everyone
My project has a problem withe linker. After compilation, the linker reported an error message:
"Out of allocation space in segment RAM at address 0x3E65."
How should I do with this messesage? My compiler option  is
-CpDPAGE=0x34 -CpEPAGE=0x36 -CpGPAGE=0x10 -CpPPAGE=0x35 -CpRPAGE=0x16 -CPUHCS12X -D__FAR_DATA -Ml -OnB=b -PSegObj -WmsgSd1420 -WmsgSd12056
Is there something wrong?
Thanks a lot for your inputs.
Pang
标签 (1)
标记 (1)
1 解答
2,779 次查看
CrasyCat
Specialist III
Hello
Apparently the memory area RAM is not big enough to store all your global variables.
I would start with looking at the map file generated by the linker. This could show you which variables have not been allocated yet.
Solutions here are:
  - If you have big arrays check if you can define them smaller.
  - You may want to place some variables in banked memory. You have then to define them in a user specified section. Please refer to technical note TN248 for information on how to do that.
Technical notes can be downloaded from our HC12 web page.
CrasyCat
在原帖中查看解决方案
6 回复数
2,778 次查看
Victim1
I keep seeing references to TN428, but have yet to find this document. Could someone supply a URL?
2,778 次查看
liyuyao
2,778 次查看
Victim1
Oops make that TN248, I can't find that either
2,778 次查看
Alban
Senior Contributor II
Dear Victim...
(isn't it the way we all feel...)
x:\Program Files\Freescale\CW for HC12 V4.x\Help\pdf\TN248.pdf
Cheers,
Alban.
2,778 次查看
CrasyCat
Specialist III
Hello
Technical Notes can be downloaded from the web.
Go to CodeWarrior HC12 product page
Click on 8/16 bit Tech Notes on the right hand side
You get a .zip file with all the technical notes.
As far as I know Technical Notes have been removed from the installation layout.
CrasyCat
2,780 次查看
CrasyCat
Specialist III
Hello
Solutions here are:
CrasyCat
