No changes on all my global variables in CW V4.6?
2,072 次查看
Pang
Hi Everyone,
I got a problem with the debugger True-Time Simulation in CW 4.6 (30 day Trial Version). When step in, I can not see any changes on all my global variables declared as followed:
file1.c
unsigned long RamPtr;
file2.c
extern unsigned long RamPtr;
I was unable to see  a change on this variable (in Registers, the value of this variable is changed indeed). Why no display updated automatically? the locals in Data:2 window, work fine.
Thanks a lot for any inputs.
Pang
标记 (1)
1,390 次查看
CompilerGuru
Please provide more informtion. Normally especially global variables are correctly displayed, so there must be something special in your setup. Try a simple wizard generated project, if it failes, post it here so we see the complete sources.
Also a bitmap showing what you see with some comments what you expect may help. Are your globals actually used?
1,391 次查看
CompilerGuru
