Managing memory in code warrior (CW HC12)
2,349 次查看
akr
Hi Can somebody guide me how to manage memory in code warrior. I am getting memory mapping error and one of my interrupt service routine is not working.
Message Edited by CrasyCat on 2009-06-19 10:57 AM
标记 (1)
1,156 次查看
CrasyCat
Specialist III
Hello
- Which CPU are you targeting (HC08, HC12, Coldfire, ..)
- Which version of CodeWarrior are you using?
To retrieve that info:
- Start CodeWarrior
- Select Help -> About Freescale CodeWarrior
- Click on "Install Products"
- CodeWarrior version used is displayed on top in the Installed Products dialog.
CrasyCat
1,157 次查看
CrasyCat
Specialist III
Hello
- Start CodeWarrior
CrasyCat
1,156 次查看
CrasyCat
Specialist III
Hello
Can you be a little bit more specific here?
When are you getting memory mapping error?
What is the exact message you are getting?
What are you intending to do at that point?
CrasyCat
