MCF51JM serial bootloader: File not found: mcf51xx_vectors.asm
905 次查看
adrianb
I'm trying to import the serial bootloader project from AN2295 and imported with codewarrior 10.1.
After that i'm getting this error at build:
'Building target: hc08sprg-v1jm128-sci1.elf'
'Executing target #3 hc08sprg-v1jm128-sci1.elf'
'Invoking: ColdFire Linker'
"F:/APPS/Freescale/CW MCU v10.2/MCU/ColdFire_Tools/Command_Line_Tools/mwldmcf" @@"hc08sprg-v1jm128-sci1.args" -o "hc08sprg-v1jm128-sci1.elf"
F:/APPS/Freescale/CW MCU v10.2/MCU/ColdFire_Tools/Command_Line_Tools/mwldmcf|Linker|Error
>Linker command file error at line 37
>Link failed.
Errors caused tool to abort.
mingw32-make: *** [hc08sprg-v1jm128-sci1.elf] Error 1
This CW10.1 Linker script change   didn't helped
Please let me know if you have any ideea
Also, attaching my project.
Adrian.
Original Attachment has been moved to: Serial_boot_FIRMWARE.zip
0 回复数
