MC9S08QE32 I2C problem with Tmp112
1,464 次查看
gpd
I'm tring to read temperature from Tmp112 sensor connected to my MC9S08QE32 via I2C bus.
I've generated the code with Processor Expert, but I never receive the ack condition, so I always read ZERO.
Is possible to see some I2C (Processor Expert) working code? Just as example.
Thank you.
标签 (1)
3 回复数
1,187 次查看
ZhangJennie
Hello Gain,
I attached you a processor expert I2C demo code made under CW6.3. you can also get it from
{CW6.3 install}\ProcessorExpert\Projects\Test projects\InternalI2C.
Zhang Jun
1,187 次查看
gpd
Hi Zhang,
I can't see the attached.
1,187 次查看
ZhangJennie
I just attached it.
can it help?
Zhang Jun
