Is there a way to run a while() loop for a limited time only, and then break away from it?
已解决
跳至解决方案
2,544 次查看
admin
Specialist II
Hi. I'm familiar with the operation of the while() loop. I would like to know if it is possible to run a while() loop for only a few seconds (3 seconds for example), and then break away from it and go down to the next instruction?
For example, in the code below:
while (sensor_value > 55)
      ........ //operation here
motor_stop();
Is it possible for the program to run the while() loop for only 3 seconds, and then breaks away from it regardless of the sensor_value, and goes down straight to the motor_stop() function?
Thx
Message Edited by Cryptical on 2009-04-13 10:37 AM
标签 (1)
标记 (1)
1 解答
1,454 次查看
J2MEJediMaster
Specialist I
Check out the break statement. Specifically, within your loop code you would write:
   if (time_interval >  THREE_SECONDS)
      break;
motor_stop();
在原帖中查看解决方案
2 回复数
1,455 次查看
J2MEJediMaster
Specialist I
      break;
motor_stop();
1,454 次查看
admin
Specialist II
      break;
motor_stop();
Thx Jedi. I used your method and it helped. Cheers :smileyhappy:
