I wanna install AN2153 boot loader on my HCS12 module
1,052 次查看
hyunkyu2_ahn
I got AN2153 code and wanna put it in my HCS12 MC9S12DP256 mcu.
I saved the code by .asm form and tried to convert it to binary form with nasm program.
But the only thing I got was error.
I have no idea how to install the code.
Would you explain the procedure to do that?
标记 (3)
914 次查看
tonyp
Senior Contributor II
Do you realize each assembly language needs its own assembler?
I believe NASM is not for HCS12 code but for x86.
(Then again, maybe it's a different NASM you're referring to, other than the popular one.)
