How to use timer overflow interrupt
3,285 次查看
dan23
Hi I’m new using codewarrior and the HCS12 T-board, onboard is the mc9s12dp512 chip.
I want to use the timer to count 1 millisecond till a overflow occurs. When a overflow occurs I want to use an interrupt to call a sub routine.
Here is a bit of my code. This interrupt implementation doesn’t work. What am I doing wrong?
void SetTimer(void)
  TCNT = 0xE0C0;
  TSCR1 = 0x90;
interrupt 16 void TimerCount(void)
  ms++;            //global variable
  TCNT = 0xE0C0;
when I built my project I’ll get the following error message.
Link error:    L1907: fixup overflow in _Vector_16, TimerCount type 1, at offset 0x0
Could anyone help me with this problem?
Greetings dan23
标记 (1)
515 次查看
stanish
Hi dan23,
Similar issue was already discussed here. You should ensure your ISR routine is placed in NON_BANKED memory. For more information  I'd invite you to see e.g.:
http://forums.freescale.com/freescale/board/message?board.id=CW816COMM&message.id=3698&query.id=1959...
stanish
516 次查看
stanish
Hi dan23,
stanish
