How to enable Processor Expert for Relocatable Assembly in CW10.4?
1,062件の閲覧回数
mylim
Hi, I'd like to find out how to enable Processor Expert for Relocatable Assembly in CW10.4 for MCU?
It seems like I only able to see PE with I select C when creating a project.
Please advise.
Thanks.
MY
3 返答(返信)
940件の閲覧回数
trytohelp
This issue was logged in our Service Request under the number 1-1263627071.
See below the Freescale  answers:
You are correct that PE option is only available after user select to create a C language project. We have no plan to support assembly project in PE. Sorry for this inconvenience.
It's same for Device Initialization, this option is only available after user select C language when creating project.
Pascal
940件の閲覧回数
BlackNight
I suggest that you create a new C project with Processor Expert, and then you simply add your assembly files to it.
That gives you everything from both world (C, relocatable assembly). You need at least some C portion as Processor Expert code is in C.
Hope this helps,
Erich
940件の閲覧回数
mylim
Thanks  BlackNight
I can see that they are killing the assembler community. :smileysad:
