Are you using the same hardware board on another computer? Would you please help me to check:
1) The connection setting in CodeWarrior
Please open Target Settings by ‘ALT’+’F7’ key, then go to Debugger->Remote Debugging panel. If you would like to use OSBDM for debugging, please choose <56800E Local FSL OSBDM Connection>. Then click on “Edit Connection” button. On the pop-up window, please check whether you have set the GDL DLL correctly. The default location of OSBDM GDI dll is: {Compiler}bin\Plugins\Support\OSBDM\osbdm-jm60_gdi_dsc.dll.
2)The OSBDM driver
Please power on your board and connect it with PC, open Device manager, can you see this device?
