How to create launcher for target- Ventilator using freescale board in CodeWarrior11
2,331 次查看
er_vishaladitya
Please provide links or documentation for How to create target launcher for the Ventilator project using freescale board in CodeWarrior11
MCU: MCF51MM256
Programmer: U-Multlilink Fx
IDE: CodeWarrior11
*Attached datasheet of ventilator module
2,153 次查看
ZhangJennie
HI
Your MCU is MCF51MM256 , but the CW you are using is CW for QorIQ which is not correct.
Please use CW for MCU for your chip:
https://www.nxp.com/support/developer-resources/software-development-tools/codewarrior-development-t...
Jun Zhang
2,154 次查看
ZhangJennie
HI
Jun Zhang
