Hi, I am trying to flash program on TRKMPC5604P eval board but it is asking for a hex password. Can you help me with this?
rutujakulkarni
PFA...
martin_kovar
could you please write me, which CodeWarrior and which version you use? Which debug probe you use?
Have you ever loaded any code into microcontroller flash?
Martin
rutujakulkarni
I am using codewarrior 10.6 version and the probe I used was USB A-B cable. We could flash program previously in that kit.
martin_kovar
when you click OK in password required window, are you able to connect to the board?
Have you ever loaded any code, which modifies Shadow flash?
Martin
