Hello forum members,   I am using Codewarrior 4.6 build 6...
已解决
跳至解决方案
2,427 次查看
SSK
I am using Codewarrior 4.6 build 6345 with MC9S12A128B. I am trying to use interrupt for SCI0 but while compiling the code , it gives following error(s) -
Error   : C1017: Empty declaration
STT25x.c line 85
Error   : C2801: ';' missing
STT25x.c line 85
Error   : Compile failed
I am also attaching a snap of the error. Your earliest help is highly appreciated.
Thanking you in advance.
标签 (1)
标记 (1)
1 解答
1,461 次查看
Stephen
Try reordering the function declaration to put the void keyword before the interrupt keyword.
E.g.
void interrupt _SCI0_interrupt(void)
 /* your code goes here :smileyhappy: */
Good luck
Steve
在原帖中查看解决方案
1 回复
1,462 次查看
Stephen
E.g.
Good luck
Steve
