HELP!!! Having General issues with Codewarrior and can't figure out why
AK88
Is anyone able to help out with a couple of questions i have already posted to this forum?  I have a project due in a week and codewarrior just started to not communicate with my device.  Don't understand the issue would like some insight.
CrasyCat
Specialist III
Hello
Did you consider submitting a service request through our on-line support web page?
You should be able to get faster response this way.
Click here to submit a service request.
In order to save time make sure to
  - log 1 problem per service request
  - attach a project reproducing the trouble.
  - specify which version of the tool chain you are using.
       To retrieve that info for version < 10.0:
          - Start CodeWarrior
          - Select Help -> About Freescale CodeWarrior
          - Click on "Install Products"
          - CodeWarrior version used is displayed on top in the Installed Products dialog.
       To retrieve that info for version > 10.0:
          - Start CodeWarrior
          - Select Help -> About CodeWarrior Development Studio
          - The version number and build number we need are the one specified under "Installed Products"
CrasyCat
CrasyCat
Specialist III
Hello
          - Start CodeWarrior
          - Start CodeWarrior
CrasyCat
