解決済! 解決策の投稿を見る。
/* .prm file */ SEGMENTS VECTOR_RESERVED = NO_INIT 0xFF80 TO 0xFF8B; VECTOR_TABLE = READ_ONLY 0xFF8C TO 0xFFFF; ROM_4000 = READ_ONLY 0x4000 TO 0x7FFF; ROM_C000 = READ_ONLY 0xC000 TO 0xFEFF; END PLACEMENT INTERRUPT_ROM INTO ROM_C000; VECTORS INTO VECTOR_TABLE; END ENTRIES vector_table END
/* vectortable_hcs12.h */ #ifndef _VECTORTABLE_HCS12_H #define _VECTORTABLE_HCS12_H /*** Include files ***/ #include "s12reg.h" /* your register map goes here */ #include "types.h" /* your uint16 etc typedef header goes here */ /*** Macros and numeric constants ***/ #define DEFAULT_VECTOR interrupt_unused /*** Function prototypes ***/ #pragma CODE_SEG NEAR INTERRUPT_ROM extern void interrupt_unused (void); extern void interrupt_reset (void); extern void interrupt_clock_fail (void); extern void interrupt_cop_reset (void); extern void interrupt_SWI (void); extern void interrupt_RTI (void); extern void interrupt_ECT_timer0 (void); extern void interrupt_ECT_timer1 (void); extern void interrupt_ECT_timer2 (void); extern void interrupt_ECT_timer3 (void); extern void interrupt_ECT_timer4 (void); extern void interrupt_ECT_timer5 (void); extern void interrupt_ECT_timer6 (void); extern void interrupt_ECT_timer7 (void); extern void interrupt_ECT_overflow (void); extern void interrupt_ECT_PACA (void); extern void interrupt_ECT_PACIE (void); extern void interrupt_SPI0 (void); extern void interrupt_SCI0 (void); extern void interrupt_SCI1 (void); extern void interrupt_PortJ (void); extern void interrupt_PortH (void); extern void interrupt_ECT_PACB (void); extern void interrupt_PLL_lock (void); extern void interrupt_SPI1 (void); extern void interrupt_PortP (void); #pragma CODE_SEG DEFAULT #endif /* _VECTORTABLE_HCS12_H */
/* vectortable_hsc12.c */ #include "vectortable_hcs12.h" /*** Function prototypes ***/ /* external interrupt routines */ #pragma CODE_SEG NEAR INTERRUPT_ROM extern void main (void); #pragma CODE_SEG DEFAULT /*** Global constants ***/ #pragma CONST_SEG NEAR VECTORS const uint16 vector_table[] = { /* */ /* $FF00:8B Reserved*/ (uint16) DEFAULT_VECTOR, /* $FF8C:8D PWM Emergency Shutdown */ (uint16) interrupt_PortP, /* $FF8E:8F Port P Interrupt */ (uint16) DEFAULT_VECTOR, /* $FF90:91 MSCAN 4 transmit */ (uint16) DEFAULT_VECTOR, /* $FF92:93 MSCAN 4 receive */ (uint16) DEFAULT_VECTOR, /* $FF94:95 MSCAN 4 errors */ (uint16) DEFAULT_VECTOR, /* $FF96:97 MSCAN 4 wake- up */ (uint16) DEFAULT_VECTOR, /* $FF98:99 MSCAN 3 transmit */ (uint16) DEFAULT_VECTOR, /* $FF9A:9B MSCAN 3 receive */ (uint16) DEFAULT_VECTOR, /* $FF9C:9D MSCAN 3 errors */ (uint16) DEFAULT_VECTOR, /* $FF9E:9F MSCAN 3 wake- p */ (uint16) DEFAULT_VECTOR, /* $FFA0:A1 MSCAN 2 transmit */ (uint16) DEFAULT_VECTOR, /* $FFA2:A3 MSCAN 2 receive */ (uint16) DEFAULT_VECTOR, /* $FFA4:A5 MSCAN 2 errors */ (uint16) DEFAULT_VECTOR, /* $FFA6:A7 MSCAN 2 wake-up */ (uint16) DEFAULT_VECTOR, /* $FFA8:A9 MSCAN 1 transmit */ (uint16) DEFAULT_VECTOR, /* $FFAA:AB MSCAN 1 receive */ (uint16) DEFAULT_VECTOR, /* $FFAC:AD MSCAN 1 errors */ (uint16) DEFAULT_VECTOR, /* $FFAE:AF MSCAN 1 wake-up */ (uint16) DEFAULT_VECTOR, /* $FFB0:B1 MSCAN 0 transmit */ (uint16) DEFAULT_VECTOR, /* $FFB2:B3 MSCAN 0 receive */ (uint16) DEFAULT_VECTOR, /* $FFB4:B5 MSCAN 0 errors */ (uint16) DEFAULT_VECTOR, /* $FFB6:B7 MSCAN 0 wake-up */ (uint16) DEFAULT_VECTOR, /* $FFB8:B9 FLASH */ (uint16) DEFAULT_VECTOR, /* $FFBA:BB EEPROM */ (uint16) DEFAULT_VECTOR, /* $FFBC:BD SPI2 */ (uint16) interrupt_SPI1, /* $FFBE:BF SPI1 */ (uint16) DEFAULT_VECTOR, /* $FFC0:C1 IIC Bus */ (uint16) DEFAULT_VECTOR, /* $FFC2:C3 DLC */ (uint16) DEFAULT_VECTOR, /* $FFC4:C5 SCME */ (uint16) interrupt_PLL_lock, /* $FFC6:C7 CRG lock */ (uint16) interrupt_ECT_PACB, /* $FFC8:C9 Pulse Accumulator B Overflow */ (uint16) DEFAULT_VECTOR, /* $FFCA:CB Modulus Down Counter underflow */ (uint16) interrupt_PortH, /* $FFCC:CD Port H*/ (uint16) interrupt_PortJ, /* $FFCE:CF Port J */ (uint16) DEFAULT_VECTOR, /* $FFD0:D1 ATD1 */ (uint16) DEFAULT_VECTOR, /* $FFD2:D3 ATD0 */ (uint16) interrupt_SCI1, /* $FFD4:D5 SCI1 */ (uint16) interrupt_SCI0, /* $FFD6:D7 SCI0 */ (uint16) interrupt_SPI0, /* $FFD8:D9 SPI0 */ (uint16) interrupt_ECT_PACIE, /* $FFDA:DB Pulse accumulator input edge */ (uint16) interrupt_ECT_PACA, /* $FFDC:DD Pulse accumulator A overflow */ (uint16) interrupt_ECT_overflow, /* $FFDE:DF Timer overflow */ (uint16) interrupt_ECT_timer7, /* $FFE0:E1 Timer channel 7 */ (uint16) interrupt_ECT_timer6, /* $FFE2:E3 Timer channel 6 */ (uint16) interrupt_ECT_timer5, /* $FFE4:E5 Timer channel 5 */ (uint16) interrupt_ECT_timer4, /* $FFE6:E7 Timer channel 4 */ (uint16) interrupt_ECT_timer3, /* $FFE8:E9 Timer channel 3 */ (uint16) interrupt_ECT_timer2, /* $FFEA:EB Timer channel 2 */ (uint16) interrupt_ECT_timer1, /* $FFEC:ED Timer channel 1 */ (uint16) interrupt_ECT_timer0, /* $FFEE:EF Timer channel 0 */ (uint16) DEFAULT_VECTOR, /* $FFF0:F1 Real Time Interrupt */ (uint16) DEFAULT_VECTOR, /* $FFF2:F3 IRQ */ (uint16) DEFAULT_VECTOR, /* $FFF4:F5 XIRQ */ (uint16) DEFAULT_VECTOR, /* $FFF6:F7 SWI */ (uint16) DEFAULT_VECTOR, /* $FFF8:F9 Unimplemented instruction trap */ (uint16) interrupt_cop_reset, /* $FFFA:FB COP failure reset */ (uint16) DEFAULT_VECTOR, /* $FFFC:FD Clock Monitor fail reset */ (uint16) interrupt_reset /* $FFFE:FF Reset */ }; #pragma CONST_SEG DEFAULT /*** Function definitions ***/ /* Unused interrupt implementations */ #pragma CODE_SEG NEAR INTERRUPT_ROM #pragma TRAP_PROC void interrupt_unused (void) {} #pragma TRAP_PROC void interrupt_reset(void) { #pragma MESSAGE DISABLE C12053 asm LDS #$2500; INITRM = 0x21; INITEE = 0x09; main(); } #pragma TRAP_PROC void interrupt_cop_reset(void) { #pragma MESSAGE DISABLE C12053 asm LDS #$2500; INITRM = 0x21; INITEE = 0x09; main(); } #pragma TRAP_PROC void interrupt_SWI (void) {} #pragma TRAP_PROC void interrupt_RTI (void) { CRGINT &= ~RTIE; } #pragma TRAP_PROC void interrupt_ECT_timer0 (void) { TIE &= ~0x01; } #pragma TRAP_PROC void interrupt_ECT_timer1 (void) { TIE &= ~0x02; } #pragma TRAP_PROC void interrupt_ECT_timer2 (void) { TIE &= ~0x04; } #pragma TRAP_PROC void interrupt_ECT_timer3 (void) { TIE &= ~0x08; } #pragma TRAP_PROC void interrupt_ECT_timer4 (void) { TIE &= ~0x10; } #pragma TRAP_PROC void interrupt_ECT_timer5 (void) { TIE &= ~0x20; } #pragma TRAP_PROC void interrupt_ECT_timer6 (void) { TIE &= ~0x40; } #pragma TRAP_PROC void interrupt_ECT_timer7 (void) { TIE &= ~0x80; } #pragma TRAP_PROC void interrupt_ECT_overflow (void) { TSCR2 &= ~TOI; } #pragma TRAP_PROC void interrupt_ECT_PACA (void) { PACTL &= ~PAOVI; } #pragma TRAP_PROC void interrupt_ECT_PACIE (void) { PACTL &= ~PAI; } #pragma TRAP_PROC void interrupt_SPI0 (void) { SPI0CR1 &= ~(SPIE | SPTIE); } #pragma TRAP_PROC void interrupt_SCI0 (void) { SCI0CR2 &= ~(0x80|TCIE|RIE|ILIE); /* 0x80 == TIE */ } #pragma TRAP_PROC void interrupt_SCI1 (void) { SCI1CR2 &= ~(0x80|TCIE|RIE|ILIE); /* 0x80 == TIE */ } #pragma TRAP_PROC void interrupt_PortJ (void) { PIEJ = 0x00; } #pragma TRAP_PROC void interrupt_PortH (void) { PIEH = 0x00; } #pragma TRAP_PROC void interrupt_ECT_PACB (void) { PBCTL &= ~PBOVI; } #pragma TRAP_PROC void interrupt_PLL_lock (void) { CRGINT &= ~LOCKIE; } #pragma TRAP_PROC void interrupt_SPI1 (void) { SPI1CR1 &= ~(SPIE | SPTIE); } #pragma TRAP_PROC void interrupt_PortP (void) { PIEP = 0x00; } #pragma CODE_SEG DEFAULT
Lundin: This is great stuff! As you well know, we get a lot of questions about interrupt vectors tables all the time here, and this code will help a lot of developers.
Thanks for sharing.
---Tom
Hmm, don't think you get around using __near with __near function pointers.
You could for example use object pointers instead (or even unsigned int with some casts). They are 16 bit by default and for the core it does not matter (for 16 bit pointers).
Or you could use the prm file with the VECTOR keyword.
BTW: use __near instead of near to be a bit more ANSI C compliant :smileyhappy:.
What about using predefined macros like this
#ifdef __MWERKS__
#define NEAR __near
#else
#define NEAR
#endif
and replacing near and __near with NEAR
