File .s19
File .s19
1,855 次查看
GTE
I am new in this. I need to load a micro-HC08 with the file s19 with codewarrior using mon08
Does anyone could help me?
标记 (1)
867 次查看
J2MEJediMaster
Specialist I
I would begin by consulting the Quick Start guide, which is often located in the CodeWarrior root directory. In the Help subdirectory, you can also look for AN2616, the Getting Started document. HTH.
---Tom
868 次查看
J2MEJediMaster
Specialist I
---Tom
