F800 in the lst file
1,977 次查看
csosza
Is it possible to generate the lst file with real addresses? The addresses in my lst file begin with
0000, however the simulator show, it is starting at F800 (register PC).
标记 (1)
1,213 次查看
CompilerGuru
Disassemble the elf file.
1,213 次查看
kef
Specialist I
Wow, nice feature, Daniel. However, *.abs file can't be opened in IDE. Abs file can be added to project files, then disassembled. And to be able to build project again (duplicated symbols in *.abs and *.o), do we need to remove abs file from project?
