Exception occurred during launch
2,095 次查看
bault10
I am new to CodeWarrior and have installed CW 10.2. When I go to run a project as a configuration, so right click on project Run As>Run configurations.. and try to run it as a Release I get the message attached as soon as a press run. What causes this issue?
2,086 次查看
ZhangJennie
Hi bault10
The problem may be caused by IDE install, workspace setting, project setting. driver,  windows application confliction or so on.
I suggest you creating a new project under a new workspace to test again. If problem persists,
Please download and install the latest CW11.1
https://www.nxp.com/design/software/development-software/codewarrior-development-tools/codewarrior-l...
you use very old CW version. version 10.2 is slower than 11.x .
CW11.1 improve the performance of old versions.
Hope this helps,
Jun Zhang
